Minimum 3D distance constraint between objects
suddy
Automotive
IN
How do I set a lower/upper 3D minimum distance constraint (like between solid objects or between entire components) in NX11? The "Assembly Constraints" allows the user to constrain two faces at a time, but I want to constrain the minimum distance between two objects regardless of their profiles(like in measure distance command).
