How To Calculate Pressure of Underground tank walls and how to calculate wall thickness.
MatthewMansfield
GB
Hello all
I was hoping someone could help point me in the right direction regarding the following problem.
I have 2 x tanks, 1 x cylindrical and the other rectangular of a given depth H that will be installed below ground with just the top of the tank exposed as shown below:-
These tanks will contain sewage and I am trying to figure out how to calculate the maximum pressure exerted on the wall of the tanks due to the surrounding soil and what thickness should the walls be in order to withstand the maximum pressures.
The tank will be installed in a location where the ground conditions are virtually dry (so I don't need to consider water pressure) and the soil is composed of hard gravel / sand.
Any help will be greatly appreciated.
Thank you.
You will need a Geotechnical Engineer to do some drilling and/or sampling of the soil at your site. He/she will be able to give you all the information you would need to calculate your pressures. Information like soil unit weight, friction angle, bearing capacity, settlement criteria, etc. Once you have this data it should be a fairly straightforward process to calculate the pressures that the soil is exerting on the tanks.
As for the tanks themselves, I won't be much help at all as I'm not a Tankologist.
I just addressed a similar problem here,
Collapse pressure of steel casing
thread507-484322
I would suggest to consider consulting mechanical engrs for the design of tanks, thanks
The Use Of Corrugated Culvert
Although metal corrugated culvert pipe has many advantages, if it is installed improperly or used unreasonably, it will not be able to achieve the desired effect and even bring about economic losses. The following items must be paid attention to when using or modifying:
1. To prevent the metal corrugated culvert from being subjected to torsion and shearing force, special attention should be paid when screwing the joint nut.
2. Reasonably select the actual bending radius R. R can be selected as follows: R=KRmin. Allowable minimum bending radius for corrugated culvert. K is the empirical coefficient. If the K value is selected too small, the hose diameter will be repeatedly bent, which is prone to fatigue failure and stress concentration; if the K value is too large, it will cause material waste and difficulty in layout. Generally selected in the range of 1~2.2.
3. In the process of use, ensure that the hose braided mesh sleeve is not mechanically damaged by knocks, bumps, abrasions, and bumps.
4. Correctly choose the nominal length L of the metal corrugated culvert. The price of corrugated culvert is higher. If the length is too long, it will increase unnecessary investment, increase flow resistance, and may cause additional vibration. However, if the length is not enough, it is easy to bend at the joint welding seam, and the metal corrugated culvert cannot work in the natural bending state, and the service life will be shortened. For the metal corrugated culvert configured with two parallel sections moving longitudinally, it should be determined as follows: L=4R ten 0.5S+△ where: R is the actual bending radius of the hose; S is the distance between the opening and closing positions of the hot plate ;△The height difference between the opening and closing position of the hot plate and the fixed joint end of the hose. Obviously, the fixed end of the metal corrugated culvert is set at the center height of the opening and closing position of the pressure plate, and L is the shortest.
We are metal corrugated culvert pipe suppliers. Please feel free to contact us if you are interested in our corrugated culvert pipes or other products.
Corrugated Metal Pipe, Corrugated Metal Culvert China suppliers--
Matthew, sorry to be late to the party --
If the tanks contain sewage, common practice in this area would be to design the tanks of reinforced concrete (potentially prestressed, depending on scale).
In that case, PCA has produced two useful guides, one for rectangular tanks, one for circular (cylindrical) tanks.
just call me Lo.
