If the drive in question involves carrying a 1 ton load, it's probably in a >8500 lb GVWR vehicle, for which EPA estimates aren't provided. But, it's not hard to find real-world experience for specific vehicles.
We don't really know what the original poster wants to do. "I am trying to determine the cost of commute to drive to a feed mill for bulk (1 ton) chicken feed." - (1) Huh? (2) So what? (3) Are you trying to make a comparison between different vehicles, or justifying the cost of doing it at all, or something else, or what's the situation?
A truck that's bigger and heavier than it needs to be, will cost you. Use the right tool for the job.
A diesel engine will usually use less fuel than a gasoline engine. But, it may cost more to maintain.
An old-school torque-converter 3-speed automatic is a fuel-economy killer compared to a modern 8- or 10-speed automatic, many of which do better than manual transmissions (because they can be better at picking the right gear for the situation than most drivers are - the control algorithms are far more advanced nowadays than they were 20 years ago).
A modern downsized but heavily turbocharged gasoline engine might achieve spectacular EPA ratings when driven lightly loaded, but be thirstier when heavily loaded than a larger-displacement but more mildly-tuned engine. There's sound reasoning behind Ford's choice to develop a 7.3 litre naturally-aspirated V8 gasoline engine for their medium-duty trucks, as opposed to throwing an Ecoboost in there.
Number one recommendation if fuel consumption matters ... drive slower. Within reason, of course.
