Modeling runoff of a small design-graded yard
RD-Design Engineer
EG
Dear All;
I have a container yard to design stormwater drainage facility (about 10 acre). As per the local standards - I have to calculate the runoff using the modified rational method for a 100 year storm event. The client requirements is to design a detention pond - and I have done so using manual calculations.
The engineer who will review and approve the design required to have the modeling using an analayis software.
I am currently using C3D but it does not have tools for that - it can be used to desig the grading or the pond (geometrically)
What is the available - free (or open source) best software for this task - i.e model the runoff and compute the discharge
Thank you all for your help
 https://files.engineering.com/getfile.aspx?folder=05a612e9-d168-4a0c-af83-7a8921f5064e&file=Concept_Grading.jpg
Have you looked at using HEC-HMS? its free and would get you closer to what you need.
