Contact US
0.02mm/m leveling on gearbox on an FPSO
0.02mm/m leveling on gearbox on an FPSO.
Is it achievable , considering FPSO is a floating structure that rolls constantly .
RE: 0.02mm/m leveling on gearbox on an FPSO
Relative to...
Relative to.... Maybe advertising...
With gearboxes in marine structures we are not so concerned about level, only alignment.
Something lost in translation?
Politicians like to panic, they need activity. It is their substitute for achievement.
I was not aware of reflector cubes... thanks IRS...
irstuff
in my old days we were lucky to obtain .001 inch (.0254 mm) tolerance with theodolite system
how precise does the one in your post post obtain, being out of the loop.
https://en.wikipedia.org/wiki/Theodolite
My theodolite (Hilger and Watts, old mechanical one about 80 years old, and in excellent shape) does 5 sec...
Modern robotic total stations are capable of distance measurement in the range of +/- 2-3 ppm, and angle measurements of .5 arcsec or less. So how accurately you can measure depends on how close you are to your target. If you're right on top of it, you'll get to the micron. If you're 1500 m away, you're going to get 1-2mm at best, assuming free stationing. If you're using an accurately laid reference grid, you can get =/- 3 ppm over any length you want; the only limiting factors will be line of sight and the accuracy of your reference grid.
so being it is accurate to 4 arc sec, then to get the best measurements getting close as possible.
we use to do both level and distance for jigs and fixtures, and station lines for aircraft and rockets.
so it can be done surely current equipment is more precise. and repeatable.
great care must be used to obtain the correct measurements.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
