Pressure Drop in Vertical Section of Gas Piping
zamakaze
Chemical
CA
hlo,
im trying to calculate the pr. drop in vertical piping for gas.
i have a vertical section where gas goes down in elevation 5 ft
the pressure at starting point is 85 psig
since there is fall of 5 ft i assume pr. gain can be calculate as = rho x g x h2-h1 where h2 is 5ft , h1 is 0 ft
for frictional drop can we just use the darcy eqn for vertical or there are some other considerations??
attachd sktch
 https://files.engineering.com/getfile.aspx?folder=9c9ff981-9471-400f-827b-b48606133c6a&file=2311.jpg
I have to ask why?
If the pressure at the start is 85 psi, then the pressure at the end will be about 84.995 psig.
But your calculation looks OK to me.
You can ignore elevation change for piping handling compressible fluids. Only the equivalent length matters for those pressure drop calculations.
