May 28, 2021 #1 Zibraz Mechanical Joined Feb 23, 2021 Messages 29 Location GB What fit would you put when brazing a shaft through a hole? I believe it's a close clearance fit (Something like a H7 g6) but I just wanted to make sure.
May 29, 2021 #2 TugboatEng Marine/Ocean Joined Nov 1, 2015 Messages 12,099 Location US It seems the ideal clearance for brazing is 0.001-.005 inch. I believe H7g6 may be a bit tight on smaller shaft diameters. Upvote 0 Downvote
