Pump discharge line vibration at 100bar
Dear Experts,
Please find the attached CII file and Site vedio. The pump discharge line is vibrating heavily before 100bar.
the process parameters are as follows; Design press= 197bar, operating press= 172bar, ope temp = 150deg C.
kindly suggest to avoid the vibration. The model frequency matched to = 6hz, no FIV performed.
Do it require damping type or special type supports?
The secondary steel portals which are exciting to be size to be modified?
https://res.cloudinary.com/engineering-com/video/u...
https://files.engineering.com/getfile.aspx?folder=...
PC
PC
RE: Pump discharge line vibration at 100bar
Either the pump is reciprocating or blower or gear pump the piping natural frequency is matching the pump frequency or multiples which cause the vibration, perhaps the system is resonating. You need to find out the the forcing harmonics of the pump and get away from them at least for 3 harmonics by increasing (most likely) or reducing the stiffness of the piping.
If the fluid is liquid and temperature allows you may need to put a pulsation dampener to the system to eliminate the mechanical and pulsation vibrations.
Thanks for your prompt response. The pump is plunger type and used for flushing water with high pressure.
That software models all the pulsation dampers, pipe supports, compliant supports, fixed supports, elbows, tees etc.
It's a real pain but if you don't you will get destructive vibrations.
Yes the pulsation damper valve is directly mounted on the pump nozzle. Even though when the pressure reaches 100bar more vibration starts.
We adjusted the support span too,but no use.
Yes you are right.we are trying to contact the vendor sending him the as-built isometric drawings for pulsation study.
https://youtube.com/watch?v=80s3fzSGvO8&featur...
Additionally, do you have vibration dampener on the suction side as well? See the installation guide below.
https://serfilcocom.blob.core.windows.net/pdfs/lit...
Your pump supplier should guide on what to do and guide you on the installation of vibration dampeners and sizing.
https://www.911metallurgist.com/blog/wp-content/up...
