NX FPCB unfold
HJ Fong
TW
I recently working on FPCB design, when unfolding FPC the components or stiffeners are not moving together even when I setup few constrains.
I check the online help ( of FPCB design and it shows my request should be doable in NX11, does anyone know how to do it? Or my request only workable on NX Flexible PCD module?
Thanks a lot, HJ
This method has become much better in later releases of NX, advise you upgrade to the latest release to get 'associate object' command that will transition your components.
However, in NX11 you should be able to get this to work with assembly constraints. Just make sure you use mate and align (and not Bond) constraints.
