Elbow 90 degrees Fabrication
Is it allowed by standard to weld two 45 degrees elbows to get a 90 degrees elbow? and whether the fabricated elbow can withstand pressure and temperature?
RE: Elbow 90 degrees Fabrication
Yes it's allowed, or rather isn't prohibited. You might not have the same dimensions as a single 90 elbow and it will look a little bit odd, but if that's all you have then OK.
Why can't you just buy a 90 elbow??
Did someone over order 45o elbows?
Good Luck,
Latexman
'Cause then you'd have to cut it in half.
It does look like 2 x 45 is the same dimensions as 1 x 90...
Is this a suggestion from a welder? They get paid by the weld. It's almost always less expensive to purchase the "right" fitting.
They are the same dims but slightly different shape. It will work but look funky.
"Funky pipework" eh?
Just think what your manager / plant manager is going to say.
"Funky" isn't the word that will be used I think....
Thanks all for your contribution.
The case that we have excess stock of 45 Elbows and I thought of using them instead remaining on the shelves.
'dogs-hash' is more like it.
If a 50% increase in installation cost is worth it...
Keep them on the shelf or sell them on ebay.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
