Abaqus results (deformed shape)
arya1996
CA
Hi everyone
I have run a model consisting of only one 2-D part. I don't know what the reason of reaching that kind of result at the end is...
It's like two 2-D sheet lying on each other...
The right image is the deformed one.
Does anyone know what the reason is ??
Thanks by the way
Check the mesh - query it to see how many elements it has. Also reopen the odb file and try with different type of plot. If this doesn’t help, double check all the settings of this analysis (you can even examine the input file to make sure everything is correct).
