May I Define Surface Hardness in Static Simulation ?
Rizkyffq
ID
Hello guys,
as the question may i define hardness on specified surface with particular depth as figure below ?
The hardness on teeth above is higher than material on below, do i can define it in static simulation solidworks 2021 ?
hopefully you may give me a guidance about this. Thanks before
SBaugh said:
wrong group, you should ask in forum1183: DASSAULT: SOLIDWORKS Simulation/FEA
Owh... Sorry2 sir. Thanks for your correction
What mechanical property is affected by "hardness"? SW and other packages do not have "hardness" material property.
