Propane Gas Volume to Liquid Volume conversion 1
zamakaze
Chemical
CA
hello all, i am trying to convert a gas flowrate of propane to equivalent liquid volume and mass.
My consumption of propane is at 0.5 mmscfd. I have tried to do following calculation by converting gas propane to mass and then using that mass and liquid density to convert to liquid volume,. Can any experts take a review and see if this calculation looks good. or if there is any mistake
Propane Consumption = 0.5 MMSCFD= 0.5 x 10^6 / 24 = 20833 scfh
This is at 100 psig and 65°F
I convert this standard flow to actual flow using ideal gas law
Tact = 65 F = 460 + 65 = 525°R
Pact = 100 psig = 100 + 14.7 = 114.7 psia
Tstd = 60 F = 460 + 60 = 520°R
Pstd = 14.7 psia
R = 10.73 ft3 psi / lbmol °R
Pact Vact / Tact = Pstd Vstd / Tstd
Vact = Pstd Vstd / Tstd x Tact/Pact
Vact = 14.7 x 20833 / 520 x 525/114.7
Vact = 2965 ACFH
Number of moles of Propane can be found by PV = nRT
n = PV / RT
n = 114.7 x 2695 / 10.73 x 525 = 54.86 lbmol/h
Propane Mol Wt = 44.1 lb/lbmol
Propane Mass Consumption = 54.86 x 44.1 lb/h = 2419 lb/h (gas mass = liquid mass; mass conservation)
Propane Liquid Density at ambient conditions (80F ) = 30.58 lb/ft3
Propane Liquid Volume Consumption = 2419/30.58 = 79 ft3/h
I only went so far as to say that "standard flow" is equivalent to a mass flow, so your effort to convert to "actual flow" is misguided. Standard flow is the information you need for further calculation, and you already have that to start with.
Calculating for the mass flow from standard flow will give the same value using gas law. So what exactly do you mean by misguided?
Your calc is correct, and you have gone the long way to compute the liq vol consumption. A shorter way is as compositepro suggested. Use whatever method makes sense to you.
There are 359.38 scf/lb-mole.
20833 scf/hr / 359.38 scf/lb-mole
= 57.969 lb-moles/hr
57.969 lb-moles/hr x 44.097 lb/lb-mole
= 2556.3 lb/hr
Liquid propane at 77 °F is 4.11 lb/gal.
2556.3 lb/hr / 4.11 lb/gal = 622 gal/hr
Your way is correct, just inefficient.
Don't worry, when you have done these for 45 years like me, you'll get more efficient.
Good Luck,
Latexman
@kkengaged - what are the units in your calculation? 113.7 -- ? , 30,669 ---- ? What is meant by dividing uncompressed measure of propane by 1000??
How can we apply this 1:270 rule to 0.5 mmscfd of propane vapor ??? to get the equivalent liquid?
Zamakaze,
He's talking rubbish just so he can get his advert in. It's been red flagged.
