Contact US
IEEE CT Saturation Calculator Question
I have a question about this calculator. Should not the secondary current be computed at the maximum dc offset? Why the calculator does not show this?
at t = 0, the peak value of DC offset current is obtained but the time at which fault strikes and phase angle of the AC voltage should be taken into account hence the computed fault current by this calculator is not the maximum.
I am not happy with this calculator. It can also show the CT is not saturating while it is not the case. Am I right?
RE: IEEE CT Saturation Calculator Question
The amount of DC offset is determined by the X/R ratio and when the fault happens on the waveform. The most offset it will be is when at T=0, the current is zero. Go review the equations in the linked PDF. The waveforms above are nearly fully offset and you can see it by the waveform being mostly positive.
https://www.kau.edu.sa/Files/0056868/Subjects/Chap...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
