RonRoberts
I have a project where the existing clarifier topping slab is being pushed up by a mix of gases that get trapped. The underside of the pile supported clarifier is somewhat dome shaped and gases are coming out of solution in that dome below and are under pressure due to the high ground water elevation. The gases (flammable by the way) work their way up thru cracks in the structural slab and then cause the group topping slab to delaminate and we get it actually forming bubbles at the trapped gas. Anyone ever try using a permeable concrete mix as a topping slab in a clarifier? I'd like to be able to let any gas that gets thru cracks vent off without delaminating the topping slab.
