rubber joint modeling in caesar ii
PIPING_DESIGNER
TN
Could you please help me !!!
How to model a rubber joint in caesar ii
If its an engineered product with known stiffness values, I'd define it as an expansion joint.
If it's essentially infinitely flexible compared to the piping (similar to braided hoses), I'd probably treat the two ends as unconnected and confirm the relative moment (expansion/contraction/offset) is acceptable per the cutsheet.
