Contact US
Calculation of raw material and product mesh sizes for crusher in chemical process plant
I have come across a problem in a textbook that I need some assistance with.
The problem is reproduced below, and asks you to determine the power input for a crusher in a chemical process plant.
The part I don't understand is 'Step 3' of the calculation procedure: Compute the raw-material and product mesh sizes (see above picture in yellow highlight).
They use the relationship: dr and dp = s/12 for calculating the mesh sizes, but where does the '12' come from?
From my research, it seems to be the number of openings in the mesh? Refer link: https://www.industrialspec.com/resources/mesh-and-micron-sizes#:~:text=Mesh%20size%20is%20referring%20to,one%20linear%20inch%20of%20screen
RE: Calculation of raw material and product mesh sizes for crusher in chemical process plant
"s = mesh opening measure used". s is in inches, abbreviated as "in."
It's just a conversion from inches to feet. 1 foot = 12 inches.
Good Luck,
Latexman
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
