Contact US
Calculateing necesary effort on steering wheel at hydraulic operated rudder
Greetings to everyone, I was trying to find administrators to reopen thread1083-462143: Downsizing hydraulic cylinder but as I couldnt, I made new tread as on of botton of thread1083-462143: Downsizing hydraulic cylinder says I can feel free to open new one. Anyway sorry for spam.
I have been trying to calculate steering effort on my hydraulic operated sailboat if I change my current cylnder.
Problem is that with my current specs I dont need to use any effort to stear the boat and there are too many turns on 70cm diameter steering wheel. And with sailboat it is necesary to have effort when sailing.
The cheepest way to do it is to change my hydraulic cylnder which is connected directly to rudder over tiller arm 18cm.
But with downsizeing cylnder I am increaseing effort on stearing wheel and I would like to know by how much and how.
Guys before gave me couple of formulas and putted them down in excell sheet down below, for each rudder angle of attack, necesary tiller arm and different speed(since speed drops automaticly when you steer trough water).(In order to calculate aproximation +- 100/200 grams)
As you can see firstly I was calculateing force of drag for each angle of attack, and than transvering forces to hydraulic cylnder, and than moment on pump shaft.
Problem comes when I try to calculate drive power of pump in wats and put it Newton-meters per second...all goes wrong.At this point I am not sure what I am doing wrong.
For exhample I get I need to use 0,06kg/s for 3 seconds to achive feedback of ruder at the end of 3 seconds of 0,54kg... but 0.06+0.06+0.06=0.18kg
It has becomed highly complex,if anyone can help me I would be grateful.
In attachment you can find excel sheet of all calculations.
Rudder transformation to calculate bhow much rudder is balanced and effective drag area
Drag coeficient used
Current connection of rudder to hyd. cylnder with tiller arm
General system overview
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
