Sealing test on a plug
Pimech
IT
Dears,
I'm designing an hydraulic oil circuit to test the sealing of a plug on an hydraulic valve.
My idea is:
- to pressurize the circuit with a pump that gets the oil from a tank.
- to adjust the pressure set point with a proportional relief valve, with electrical control
- to close with a shut-off valve the circuit related to the plug
- to monitor (e.g. for ten minutes) if there is a pressure drop in the closed circuit.
The required test pressure is 1 MPa +-0.005, but I could extend the range with an higher upper tolerance, since it will be conservative.
My doubts are related to the fact that the circuit will be small (a few centiliters of oil) and I may not have much control over the pressure.
Do you have any suggestions? Eventually even on the choice of the proportional relief valve.
Thank you
For things like this people tend to either use a small hand pump or adjust air pressure over an oil reservoir to allow much finer control.
Using just oil will be harder.
Or a dead weight pressure tester.
Not sure why you're trying to solve a problem which has already been solved many times before.
Thank you,
the air pressure over an oil reservoir is an option that I was evaluating.
Probably I will use an air oil multiplier.
