Need help identifying MUTCD sign code 1
mellowmentality
I am trying to figure out the proper MUTCD sign code for a named parkway - for example "John Doe Parkway." Does any one know the appropriate MUTCD sign code I should use? The existing signage is a brown sign with white border which would indicate to me it would be a cultural/recreational sign, yet I am not sure it qualifies as a dedicated or memorial highway either. I am trying to figure out which sign code I should put on the plans. Thanks in advance.
If it's a wide, short sign that says
John Doe Pkwy
You you could call it a D3-1.
If it's as high as high like a route number marker, like
John
Doe
Pkwy
check your state supplement and see what they call it. For example, New York uses the code "NYM5-1" for parkway markers and similar signs.
My glass has a v/c ratio of 0.5
Maybe the tyranny of Murphy is the penalty for hubris. -
