Reinforced Concrete Design - Structural holes
I am just wondering if one can plan for shaft/chase holes near columns. Is there a rule of thumb in placing holes?
Your response would be appreciated. Thank you very much.
RE: Reinforced Concrete Design - Structural holes
You generally try to have openings in the "middle" strips (where possible). See Sect. 13.4 of ACI 318-11 for some guidelines.
What you are talking about can be done (with the checks performed).
Note that in the less common case of two-way beam-supported slabs, the ideal location is in the intersection of column strips (but not in the beam). Depending on your floor, some shear and deflection checks may still be required, but these are generally easy to solve.
just call me Lo.
