Contact US
What is a good program to do steel bridge shop drawings?
RE: What is a good program to do steel bridge shop drawings?
Personally, I dont know much about detailing software. However, a few years ago I had a fancy pedestrian bridge project and the fabricator used Tekla to preoduce the SD's because of the 3-D modelling capability. It produced very good drawings.
Take a look at an issue of Modern Steel Construction from AISC; in the back there are advertisements for detailing software.
AutoCad & Microstation come to mind.
You can look at Bentley ProStructures if you want piece marking capabilities. I used it to model a steel bridge once but it was way too powerful for contract drawings and doesn't handle curved member well, though. This was for a vertical lift bridge and it worked pretty well for that.
I would maybe reach out to High Steel or some other fabricator and see what they use.
I have seen several shop drawings produced by Tekla Structures.
Generally I've seen some companies use SDS2 for structural steel shop drawings.
Tekla 3D is another one that is used.
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
