PSV can be installed in Horizontal position? 2
Nasim12345
Industrial
SA
Dear
Can you please inform me, whether the code is allowed to install PSV in horizontal position. If yes, is it possible to share me the procedure paragraph
We noticed today that, one PSV was installed on the pump in horizontal position.
Nasim
API 520 Part II, Section 13.1
Good Luck,
Latexman
In addition to the API-520 II advise provided by Latexman, There is similar mention also in current ASME VIII (2019) Non-Mandatory Appendix M-11 (see attached).
Since you advise that you have such an existing installation, it is is strongly recommended that you;-
* Check that such an installation has been reviewed and allowed by the manufacturer
* That documentation exists that the PRV installation has had proper assessment according to the noted API/ASME sections
The manufacturer should have been advised of the set up and also offered their advice and possible modification. For example;-
- Testing of the valve would have been done with the valve in this orientation
- Depending on application, some internals of the PRV may have needed modification (eg. guiding materials)
- Depending again on orientation, valve design and application, the PRV may require draining points
- Additional instructions in maintenance manual to cover such installation
You may need to address these issues through the pump supplier if the PRV came fitted already on it.
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
 https://files.engineering.com/getfile.aspx?folder=4a18513d-fcc8-45ec-944c-e6819da4663f&file=ASME_VIII_(2019)_Non_Mand._App._M-11.JPG
Greater possibility of dust and dirt collecting in the PSV internals when in the horizontal position.
@The Obturator
In many of my posts I have hailed georgeverghese Sir and Latexman Sir as awesome experts in the field of Chemical Engineering / Process Plants / Oil and Gas Installations etc.
I do the same for you in the field of PSVs. A star for you.
DHURJATI SEN
Dhurjati Sen Thank you so much for the recognition and accolade. It is nice to be appreciated. Thank you.
