Our company has a project in which we are installing new avionics in a Aerobatic General Aviation aircraft. In the aircrafte frame, there are existing holes though which wiring harnesses are routed. For the added avionics harnesses, we want to increase the size of some these holes and in certain case add new holes.
What analysis / calculations are required to determine if the frames can be modified?
If the frames required reinforcement after making / enlarging holes, how to design the reinforcement scheme?
What data is required to perform this analysis?
Thanks in advance
Thanks in advance
