Change node coordinate dimension when exported
Dav3dum
HU
My question is, that is it possible to change the coordinate's dimension when exported into a csv via identify result?
I've tried change the default length setting to an other dimension, yet the coordinate's column remained in the original one
Thank you for you help in advance.
