Question: liquid pressure
Hi community!
sorry, this may be a stupid question :D and not sure where to post it..
I have the following case: a tank with a pipe connected to its bottom, closed with a plug is partially filled with a liquid (red); the tank is pressurized with compressed air (light blue) from its top, let's say at 8 bar.
Valve at the bottom is opened, so the pipe is filled with liquid.
In this situation the manometer will read 8 bar.
Now, I'm closing the valve and I'm depressurizing the tank from the top: I have atmospheric pressure in the tank now.
What value the manometer will read? I think still 8 bar?
RE: Question: liquid pressure
Andrew H.
www.MotoTribology.com
So it will be more than 8 bar.
If you then isolate the bottom section this will stay at 8 bar providing there is ZERO leakage across the valve or change in temperature. Any losses of fluid will reduce pressure, any positive change in temperature will increase pressure
What you will be reading is a gauge pressure ! be specific about the unit absolute or effective.
my 2 cents.
Pierre
