Error regarding importing a CAD body model into Adams/Car 2
bj77
Automotive
Dec 19, 2020
12
hello
I have imported a CAD model from Catia into Adams and solved the problems of importing it with the help of the guys here.
i have created a body template with this model.
i have defined communicators, requests, parameter variables and hardpoints for the new model the same as "subcompact" body template model in Adams/Car
another problem has occurred...
i encounter this error:
would you please help?
thanks for the members of this site and experts helping us
i have gained a lot during the stint of my stay here[bigsmile]
what does it mean by center of mass???
what center of mass?
what have i done wrong?
should i also define the pointed input communicators for the body template??
the subcompact default model didn't define any other input temlates more than i did... or have i done something wrong?
Every part needs a centre of mass marker. I don't understand why it thinks a force needs a CoM. I suspect the problem is in your template.
Cheers
Greg Locock
thanks for responding but i'm still stuck here...hope you can give me more...still working to find the problem
Warnings shows that a one of marker has been renamed you. I think it somehow influenced to results…. Try to make a template with a minimum of changes:
1. Load a standard template. For example the same subcompact.tpl
2. Import the CAD model and position it as required.
3. Using the Aview interface, use a fixed connection (lock) to bind the CAD-model bodies (hopefully there are not many of them) to the already existing body "ges_chassis". The mass can be taken into account either in the CAD models themselves or added to "ges_chassis".
4. Use the right button to hide the elements of the standard chassis unnecessary for display.
5. That's it! Then, just try to save the template and create a subsystem….
Thank you very much this solution seems reasonable and feasible...that's great … I'll try it and keep you apprised.
I appreciate it a lot
