FOX embedment factor correction | how to find the equation? 3
Lauramps
Hi! I am currently working with settlement in shallow foundations, and we need data on some "If" values (depth correction factors) for analysis - I've searched all around, and got to MITTAL's paper and even to the original FOX's paper for his equations - however, I wasn't able to achieve the same results when trying to apply his formulas in softwares such as matlab or excel, due to some factors:
- On his final table, ( page 6 for reference), Fox specifies ratios for L/B and Df/B - however, we couldn't quite point out which data he used to achieve these results. For example, there are many possible values for L, B and Df that might result in a same value for the L/B and Df/B ratios. When applying his formula, I find many different results for different values used, but we could never quite reach que same result as the table/chart.
- We can't quite figure out if we might be making a mistake when writing his formulas down on the software -
These are some threads I've visited when researching - I've found some programs but I couldn't figure out how to run them, although I've tried to run some c++ compilers before; the install file just won't seem to run on my computer. Still trying to figure out if I might be able to run it somewhere else.
thread256-25162 This is an older thread from someone who was also searching for a spreadsheet model for Fox's equations - However, I couldn't find a way to contact the people who could have them :(
I'm aware of other authors that have worked with Fox's values such as Mittal, Mayne and Poulos and many others - however, for precision reasons we need to pinpoint Fox's equation results necessarily. Is there any paper or program I can reach to find help with that?
In advance, I apologize if it sounds confusing - my english is a bit rusty, but I'm happy to explain it further if needed.
- that is a printscreen from my matlab running and some of the formulas I'm trying to use.
- that is Fox's article with his original formulas, which we're trying to apply for a number of different B, L and Df combined values for analysis.
BigH,
Hi! I am familiar with Mittal's article - what I'm looking for is for someone who might have worked with Fox's original article and equations, since Mittal developed his' by using artificial intelligence. By looking into Fox's original paper, we couldn't point out which data he used for his equations, because when punching it into excel/matlab or another software, our results seem weird and far off from what we're looking for.
Most specifically, I guess I'm looking for some old people I've seen here developing a spreadsheet or other kind of program using Fox's original equations for the IF factor so that we can test our data and see what whe're doing wrong.
Appreciated!
Lauramps,
I made a simple spreadsheet to calculate influence factor from the Fox equations.
The IF appears to match the Pg 6 Table values, in checking a few different footing sizes & depths..
You might try comparing results from this spreadsheet to help debug your matlab sheet.
Good luck,
Carl
 https://files.engineering.com/getfile.aspx?folder=f83de91b-37fe-4527-8e2c-4c61f770d00b&file=Fox_Influence_Factor.xlsx
