Equation of Fox's depth influence factor
RE: Equation of Fox's depth influence factor
Here is a link to ELASTIC SOLUTIONS FOR SOIL AND ROCK MECHANICS by H.G. Poulos and E.H. Davis, 1974
http://research.engr.oregonstate.edu/usucger/PandD...
Many different approaches to elastic stresses due to a dizzying array of loadings.
Hi jdonville,
Thank you very much for the invaluable information with the link. I will look thru it to see if I can find the Fox equation or try a different approach from the link provided. I suppose if worse comes to worse, I can always manually look up the values and plot a few points to try to curve fit the depth influence factor.
Your information is much appreciated.
I think that Bowles book has available that equation in his book's CD.... but if you do a google search you will be able to find it.
The program was created on C++ or some similar old programming language. Our IT folks had that language available in their PCs so we could tabulate the values in EXCEL so we reproduced the graph.
Hi Okiryu,
Thank you very much for your input. I have a copy of Bowles book but no CD. I have not been able to find Fox equation from my google search yet. I will keep trying again. Thanks again.
Hi Okiryu,
Thank you very much for the valuable information. It is much appreciated.
Hi CarlB,
Thank you very much for the Fox article and the related article of interest. It is much appreciated.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Implementing a Multi-Domain System
IoT systems are multi-domain designs that often require AMS, Digital, RF, photonics and MEMS elements within the system. Tanner EDA provides an integrated, top-down design flow for IoT design that supports all these design domains. Learn more about key solutions that the Tanner design flow offers for successful IoT system design and verification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
