Residual Stress after Permanent Stress
I have a case that the metal rod being bent to L shape and continue to pull it.
There is no heat treatment and there should be residual stress after bending into L shape. If I run two analysis separately, 1. plastic deformation to get the total strain;2. max stress/ strain when the L hook being pull, then sum up the total strain for assessment?
RE: Residual Stress after Permanent Stress
Engineers, think what we have done to the environment !https://www.linkedin.com/in/goutam-das-59743b30/
