For a residential structure, do you guys provide embed plate and shim space for beam bearings? I want to provide some tolerance for the wall construction. Beam/weld plate to me is a must.
Yeah unless for some odd reason there is a need for positive connection (maybe uplift or lateral) I'd just pocket it in and they can adjust the elevation with shims, then grout it all into place. That's for residential where bringing out a welder would guarantee I never work with that contractor again. I also rarely trust them to put the anchor bolts in the correct location, "What's an anchor bolt template?".
