Contact US
api 5l grade x52
api 5l grade x52
api 5l grade x52
hi.
could you please tell me is it possible to use api 5L gr. X52 welded pipe (PSL1) instead ASTM A671 gr. CC60 pipe ? note that min. temperature is -55 c
RE: api 5l grade x52
Possible? maybe, but you need to decide if the differences are within your ability to accommodate or not.
Generally API 5L doesn't like going much below -40C
You need a materials engineer and also look at the physical properties you need and the differences between them.
Not likely but you need to check with manufacturers.
You forgot to mention some critical information. You don't even say what you want to do with this pipe.
Thanks all of you. this pipe would apply in an area between pressure vessels. I have not more details about design. we received this order from our client and only thing they have mentioned on that was impact test in -55 c. their order was for ASTM A671 but we can't supply this material right now and going to offer them API 5L grade b.
Well good luck trying to convince your client about that. ASTM 571 cc60 also seems to come in a large variety of grades.
5L grade B isn't the same as grade x52 and psl1 is a lower grade than psl2.
Your A671 Gr CC60 belongs to T group CS-C (refer B31.1 Appendix-VIII) for which min temperature is more than 29 deg C. It is doubtful whether you can use API 5L Gr X 52 for temperature -55 deg C as all alloy steel/CS pipes has min temp more than -29 deg C. You may have to use other metals like Nickel alloy etc.
thanks all of you dear friends.
We purchased CC70 pipe, impact tested at -55C nearly 30 years ago for a project in Scotland. All WPS were qualified at -55C as well of course. Nickel content of filler metals was 1.0% max. Max thickness of pipe was a bit greater than 2 inches. It would appear that the appropriate Code of Design/Construction would be ASME B31.3 - not B31.1.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
