Allowable stress value of A105 1
AliGrailly
IR
How Calculate the Allowable stress value Of Flange A105 At 93 Degree (Celcius ) ?
What is your Question?
1. Do you want to calculate? or
2. Do you need the value?
Allowable stress value are provide i the Tables for ASME I, VIII, in ASME II and in the Tables in B31.1 and B31.3.
For reference, per B31.3, the Sa of A105 in terms of temperature are:
65 Deg-C: 156 MPa
100 Deg-C: 151 MPa
150 Deg-C: 146 MPa
You're supposed to be an engineer right?.
You extrapolate between the two nearest temperatures in a straight line
So about 152 MPa
so, As much as increase Degree happened decrease stress in tension and we have to consider value of the highest temp than that if not available in table
Look up the word "extrapolate"
Thanks everybody helping me
Finally
X=(93−100)×(156−151)÷(65−100)+151=152Mpa
Finally!
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
