Luis camposano
Greetings to all:
Could someone have the solution to the following case.
The following figures correspond to the same 50x50 centimeter section of a column modeled in "Section designer" in ETABS.
As can be seen in one there is greater shear reinforcement (confinement bars); the problem that arises is that both have the same moment values, when in reality, one must withstand greater moments than the other.
I hope that a colleague has the solution to this incongruity.
Thank you
Thank you
