elevator structure limits
mekafime
PE
Hi, I try to design a steel elevator structure, pls what are the load combinations ultima and service conditions, could you tell me the standard?
mekafime,
According to your profile, you are from Peru. I have no idea of how Peru identifies engineers qualified to design elevator structures. You had better find out. Having done that, you probably need to learn your local building codes.
JHG
