Joining surfaces
Joining surfaces
How do you mate 2 surfaces in MDT?
Let's say that you have two surfaces represented by two sheets of paper. Each has 2 straight edges and one curved edge.
Starting at a corner of the straight and curved edges, you put the two curved edges together. With paper and cellophane tape, after joining the curved edges, you have a sort of cup shaped surface
If I create these two flat surfaces in MDT, is there a way to join the two curved edges that will result in the same cup shaped 3D surface?
