Contact US
maximum allowable magnetic flux density
Hi all,
I am working on the design of switched reluctance motor. The attached file shows the magnetic flux density in rotor and stator as well as the B-H curve of corresponding material. The rotor and stator are in saturation region. What is the maximum allowable magnetic flux density to have good performance in long time?
RE: maximum allowable magnetic flux density
Long term performance isn't the issue, you're wasting magnetic material if you are operating into deep saturation.
For a spinning motor you are always going to have areas that are well into saturation on a regular basis. That's because the conducting area goes from a small amount (teeth moving towards each other) to a large area (teeth line up perfectly) back to a small area (teeth moving away from each other). I don't have any experience with switch reluctance motors but I know that with our universal motors a good bit of material is saturated quite a bit of the time.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
