section view in nx1919?
scottylutz
Automotive
what happened to project section view in nx1919? I cant seem to find anything there now. it seems they have added "section line" but the old command of section view is not available.
Is this Modeling or Drafting ?
In Modeling, right click in the whitespace of the assembly navigator and check "include sections" if that line isn't visible.
Tomas
For me, it is next to the section line command (see screenshot). After installing NX 1919, I switched to the advanced role. If you do not see it in your ribbon, you might need to customize the UI to display it.
www.nxjournaling.com
There was a similar thread on the Siemens community site not long ago about the base view command missing (I can't find it now because their search is terrible). IIRC, the fix was something fairly easy such as deleting the user.mtx file and restarting NX. My memory is a bit hazy on it, though. You might consider contacting your reseller/GTAC to get their recommendation.
Edit: a Google search found it when their internal search couldn't seem to.
so, i have gone into my settings and cant find the trigger for this. others in my work group have the section view command but mine shows as unavailable in the command finder. where can i turn this on to make it available?
