gtallens1979
Hello All:
We have a customer that is using a VFD basically as a starter on a motor due to in-rush limitations not allowing them to use a soft-starter only. Once the motor gets up to speed, they no longer utilize the speed variability in the VFD. The motor runs at full load speed.
My question is if that is the case, does the PWM coming from the VFD discontinue or is it there because the voltage and current are still coming through and from the VFD to the motor?
Thanks in advance.
Thanks in advance.
