Anyone know what the clearance requirements are for a 15kV (13.8kV nom) generator neutral bar? This is the neutral bar within the generator terminal box and would typically have leads T2, T4, T6 landed on it.
Is there any code requirement or industry standard I could refer to? Live phase conductor clearances are clear and available in numerous codes, but not sure about the neutral side.
Nominal current of generator would be ~300A at 13.8kV.
