Weld chart for aisi material?
So i've found a website that lists the P-numbers of base material ( http://pnumbers.com/ ). This covers asme materials. Is there a comparable chart for aisi materials like 4140? The welding shop we use can weld all p1 materials like 1018 to a105 and such but what about 4140 to a105?
RE: Weld chart for aisi material?
The welding requirements come from your selected code
Are you building/welding something in conformance with ASME-VIII, or AISC or API ? ... Select your construction code and review requirements.
I am not aware of any "P-number" system existing outside of ASME rules
MJCronin
Sr. Process Engineer
