How can I save my material properties in ANSYS Fluent 2020 R2
I am using Fluent module in ANSYS Workbench 2020 r2. I know that I can load a material database by means of a .scm file. I have to do several analyses and I would like to save the material properties that I have defined in the first one and then load in the following ones. How can I save my material properties in an .scm file (or other format that is compatible with Fluent)?
I thank you in advance,
AndradeSilva
AndradeSilva
