Contact US
Through thickness crack on Inconel 625 Forged Flange
Dear Experts,
It is very strange that one of the small bore flange made of Inconel 625 forged (ASTM B564 UNS 6625) got a through thickness crack just near the tapering portion of a flange. The crack was noticed while performing the hydrostatic test. The thickness at the bevel end is 5 mm and the crack was just 25 mm away the GTAW weld. we are currently investigating the failure.
Expert's view and suggestions based on rich experiences will help us to find the real root cause. What could be the reason for such a material failure that too in forged flange of MOC UNS 6625?.
RE: Through thickness crack on Inconel 625 Forged Flange
Is the manufacturing procedure in accordance with the qualification technical report of NORSOK M-650/ISO 17782?
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
I would start examining the forge procedure for forge reduction ratio and start and re-heat temps, along with how those temps are controlled and verified.
There was no penetrant inspection required?
First step is to check the material by chemical analysis and not by PMI.
DHURJATI SEN
Tapering, hydrotest...These would be the keywords...
Check whether there is sufficient thickness kept after tapering. Generally, tapering, which is to reduce stress concentration by placing in elastic zone of stress & strain curve, could induce thickness reduction over threshold limit.
Conversely, if its thickness is sufficient, make sure that the stress concentration has not crossed the elastic zone.
If the crack happened during "hydrotest", it would not be an issue of corrosion resistance but strength itself.
SiHyoung Lee
Possible causes:
1. Material impurities: flange or welding materials
2. False manufacturing procedure : forging, welding, annhealing, tempering
3. Failing or not thourogh enough inspection
4. Mechanical forces larger than allowed: bolting torque, bending flange force, missing pipeline support.
5. Pipeline externly loaded, used as ladder or weighted otherwise.
Normally such faults will start as an impurity in the material (point 1 and/or 2) followed by 3, often enlarged or occuring by 4 and 5. The rest is analysis and recheck.
You should also check if this is a one-time or systematic failure influencing other flanges.
What country was the flange manufactured from ?
MJCronin
Sr. Process Engineer
do standard weld repair, and NDT to verify removal.
Quote (Ishack)
The interweb is not very good at those things. Just saying.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
If you really want to get to the root cause, then you need to include a metallurgical failure analysis of the flange. I would also want to note that the fact that the crack appeared during the hydrotest does not mean it formed from the hydrotest. It may have already been present but opened under the pressure. Finally, you note the crack was "just" 25 mm from the GTAW weld, but that 1-inch distance likely would put it out of the heat affected zone.
Weld cracks are frequent and have to be radiographic inspected. Before and after a repair.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
