KICKER STAAD MODEL
astridmcb
PH
Hi guys, I am in need of help.
I am confused, what are kickers? This is for vertical aluminum mullions, 7m in height. How can I apply these kickers on my staad model (photo below) to reduce mullion's buckling?
Please bear with me, I am new to this.
An illustration would be really helpful.
Thank you!
Based on my experience in the curtain wall world (which I am guessing this may be), we would typically describe a kicker as a structural assembly used to provide an additional lateral support point for vertical mullions - I am attaching a sketch of something similar.
And they usually end up exposed, or enclosed in some manner, so usually only used when all other options are exhausted.
 https://files.engineering.com/getfile.aspx?folder=0ff517fe-eb1a-401f-8143-a8af94eb0a4f&file=kicker_sample.pdf
You need another connection joint outside of the mullion's axial axis in order to provide a kicker. A kicker is a short member, usually, diagonally connects two other main members to form a triangle shape around a corner.
Yes correct, this is curtain wall. Noted on that. So if I put a point support (for kicker) midway on the vertical mullion, what would be my release? I'm assuming to add it as a fixed-but support to restrain wind load.
Kicker usually has no bending capacity, nor it is desired.
