What is the recommended fabrication tolerances for the top plate flatness of the rectangular tank?
There is no limitations or guidance in any of the standards. As a good practice +/- 5.0mm tolerance measured between the distance is < 500 MM should be ok ?
Any expert opinion and references. Please share.
pnrngv
pnrngv
