Problem creating a Tee
Hi.
When trying to create this specific tee, the software does not display the pipes properly and there is a gap between the pipes. And only this one has problem, there is no problem in other elements and tees.
I checked the nodes and there seems to be no error. I also closed and re-opened the program but the issue is still remained.
Below is a picture of my problem attached.
I would appreciate if you could help me solve this issue.
RE: Problem creating a Tee
I'm not even sure whether it is just a graphical issue or has impact on the calculations as well. Is there any way to check if it affects the results?
Richard Ay
Hexagon PPM (CAS)
