LPG Natural Vaporization calculation to findout the requirement of extra vaporizer.
Dear Experts,
I'm installing a 450 Kg LPG tank to supply gas to several residential flats. Please let me know how many double burner stoves i can connect with the tank through a piping network without using any extra vaporizer. There will be natural vaporization from the storage tank by ambient temperature.
If there is any calculation, Please give it here. Though I'm not a mechanical engineer i dare to get the knowledge from you.
Please share your knowledge.
Thanks in Advance.
Thanks in Advance.
RE: LPG Natural Vaporization calculation to findout the requirement of extra vaporizer.
This is a bit of a backwater of a forum so you may not get many replies. Might be better to repost in Chemical process engineering.
I would have thought that the LPG vendor or tank vendor could give you this, but you will need to know surface area of your tank, minimum ambient air temperature and gas flow rate to do any calculation.
I think the answer will be quite low flow unless you're in the Middle East or somewhere it doesn't get lower than 10-15C. Also depends on how long the flow goes on for as the temperature of the liquid will fall, but if this is only for say 5 minutes you might be OK.
Also "LPG" is rather vague. You will need to know what the percent Propane/Butane is or if it's 100% Propane and get the pressure / temperature curve from the suppliers.
Why the reluctance to install a vapouriser?
The LPG turns out to be 70% butane so I suspect this table is rather optimistic compared to 100% propane?
