DTA - Antenna Installation at non-pressurised fuselage
I am working on antenna (with 20 Kg mass) Installation at non-pressurised fuselage, after pressure bulk head. The antenna is installed directly on Stringer with Stringer coupling, and there is 2" x 2" square hole on fusealge skin for ELECTRICAL Provision. This hole is reinforced as per OEM SRM Skin repair. As per SRM, there is no inspection interval mentioned for Skin repair and Stringer repair. Do I Need to DTA and calculate the inspection interval? or only the static calculation is enough?
If I Need to do DTA, what load is to be considered?
RE: DTA - Antenna Installation at non-pressurised fuselage
Reinforcing the hole "as per SRM" is probably good enough for the hole, but what about the loads from the antenna ? a 20kg antenna is not small. What are you doing for buffet loads ? A 20kg antenna is a scary, seriously scary, thing to be adding to the plane and needs a lot of internal support provisions.
DTA is just about the least of your problems. If there's no buffet stress, then you could use hoop stress as a hopelessly conservative 1/flt stress and run some DTA calcs at the dblr edge. So you'll probably end up with a LFEC inspection 1 every 5 or so years … not a problem in the mod world.
But you Need to have a sturdy internal provision to ensure that the installation is stiff enough to avoid problems (being too flexible). If this was a VHF antenna, I usually use an abuse load (200 lbs, 300, 400 ??) at the tip to demonstrate an acceptably stiff structure.
FAA PS-AIR-25-17 STRUCTURAL CERTIFICATION CRITERIA FOR ANTENNAS, RADOMES, AND OTHER EXTERNAL MODIFICATIONS
Regards, Wil Taylor
o Trust - But Verify!
