Residential roof truss interior walls being removed. 1
shacked
I have a client that wants to remove some interior wood stud walls in a single story house. The roof system is 2x4 roof trusses and span approximately 30ft. Let me also say that I have very limited experience with roof trusses and probably no knowledge of typical rules of thumb concerning design of residential roof trusses.( I specialize in custom residence and hillside homes)
I have attached the roof plan with dashed red walls to be removed.
I went into the attic at the wall line at the red cloud to the right, behind the master bedroom and I verified that there is gap between the bottom truss chord and the dbl 2x top plate. Based on this I am assuming that that wall line in non bearing.
This is located in Southern California so there is no snow load so I do not believe that truss arching would be an issue here.
My question is, in lieu of running a calculation for the truss would a field observation such as this be an acceptable way of determining if the roof trusses are bearing on an interior wall?
 https://files.engineering.com/getfile.aspx?folder=9d964db9-6b79-4a6f-878f-31586b4f763d&file=ROOF_PLAN.pdf
If they are factory built, metal plate connected trusses I would expect that they are designed to clear span and that none of the interior walls are load bearing.
I agree with dauwerda. 30 feet is nothing for metal plate connected trusses. And since you did the proper homework and went and confirmed the presence of a gap, you're already a step ahead. With the gap there, that would confirm to me they're non-loadbearing. It's odd that there's a gap, because honestly in single family residences where I practice, almost no one puts in the appropriate gaps.
I agree with the comments above, but will add another observation. If the location of the wall does not line up with a panel point in the bottom chord of the truss, it is almost certainly not a load bearing wall. A load bearing wall typically would not provide support to the bottom chord of a pre-engineered wood truss between panel points.
Thanks guys, that is exactly what I had assumed, all of the above.
I agree with all the comments above. I would just add "provided they are not scissor trusses". The panel point location is one of the best indicators it is not load bearing even on a scissor truss.
even if clear span and not interior bearing walls, just be cautioned that you can have some minor cracking due to the change in the loading regime.
