Test Set Relay VEBKO AMT105
NellyEng
TN
Dear all.
thanks for this great Forum
We're currently looking for a relay tester.
We're trying to find one with a full relay database and easy to set up.
Right now, we have a Ponovo : PW336i 6*15A, 4*150V . But we need and product with more 100Amp to run it for primary and secondary testing, it is not possible with this one.
we are now in contact with an relay tester company named VEBKO,from Iran
i have an positive feed back about his tester VEBKO AMT105 from some friends, but i need your's also because it's chaeaper than any others in the same capacity, with 15,000 Euros .
Please i need your experience with this device
Thanks for your kind help
Edvard
NellyEng,
What is the VA rating at 100A you expect?
Your selection depends on the power output desired at expected current setting. And how much time you need 100A? Please check with the manufacturer the operating time at 100A . Does this device need cooling time after you use 100A output ?How much is that time? is it acceptable to you? Please check with the manufacturer about such details.
Specifications wise the device looks state of the art.
